Einleitung
This guide will show you how to remove the back panel of your camera.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
Keep your finger clear of the battery when it pops out.
Lift up the bottom back cover by prying the bottom edge with the spudger.
Gently lift up the back cover with your hand from the bottom to the top.
Lift the tabs on the ZIF connectors.
The ribbon cables should easily come out of the ZIF connectors.
Fast fertig!
Abschluss
