Einleitung
This guide will help you remove the back panel buttons so you can install new ones.
Was du brauchst
Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
Keep your finger clear of the battery when it pops out.
Lift up the bottom back cover by prying the bottom edge with the spudger.
Gently lift up the back cover with your hand from the bottom to the top.
Lift the tabs on the ZIF connectors.
The ribbon cables should easily come out of the ZIF connectors.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
