Einleitung
This guide will take you through the steps of how to replace the flash assembly.
Was du brauchst
Push the small gray tab on the top right corner to the left. The battery will pop out slightly.
Keep your finger clear of the battery when it pops out.
Lift up the bottom back cover by prying the bottom edge with the spudger.
Gently lift up the back cover with your hand from the bottom to the top.
Lift the tabs on the ZIF connectors.
The ribbon cables should easily come out of the ZIF connectors.
Using the spudger, pry off the top cover by gliding the spudger along the entire edge between the top cover and the front cover.
Lift the logic board out with your hand by pushing the tabs out and pulling the logic board up.
