Zum Hauptinhalt wechseln
Panasonic Lumix DMC-FX37 LCD Screen Replacement
Was du brauchst
  1. Panasonic Lumix DMC-FX37 LCD Screen Replacement, Panasonic Lumix DMC-FX37 Disassembly: Schritt 1, Bild 1 von 2 Panasonic Lumix DMC-FX37 LCD Screen Replacement, Panasonic Lumix DMC-FX37 Disassembly: Schritt 1, Bild 2 von 2
    • Remove both of the 3 mm screws on the bottom of the camera connected to the side panel.
  2. Panasonic Lumix DMC-FX37 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Panasonic Lumix DMC-FX37 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the remaining 3 mm screw holding on the side panel and remove the panel entirely.
  3. Panasonic Lumix DMC-FX37 LCD Screen Replacement: Schritt 3, Bild 1 von 2 Panasonic Lumix DMC-FX37 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • On the opposite side of the camera, remove the two 3 mm screws.
    • Remove the bottom side panel and place it with its respective 3 mm screw.
  4. Panasonic Lumix DMC-FX37 LCD Screen Replacement: Schritt 4, Bild 1 von 3 Panasonic Lumix DMC-FX37 LCD Screen Replacement: Schritt 4, Bild 2 von 3 Panasonic Lumix DMC-FX37 LCD Screen Replacement: Schritt 4, Bild 3 von 3
    • Remove the front panel (the panel around the lens casing) from the camera.
    • Remove the two ribbon cables connected to the back panel (the panel this the LCD screen) by lifting up on their respective tabs and gently pulling out the cord.
    • Caution: When removing the back panel, the two ribbon cables are relatively delicate and must both be disconnected before the panel can be entirely removed.
    • Remove the back panel from the camera.
  5. Panasonic Lumix DMC-FX37 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Remove the top control panel (connected to the flash battery) from the camera.
    • The top control panel is connected to the rest of the camera by a delicate multi-pin plug. Be careful as to not bend the pins!
  6. Panasonic Lumix DMC-FX37 LCD Screen Replacement, LCD Screen: Schritt 6, Bild 1 von 1
    • Use a plastic opening tool to pry off the LCD screen.
    • There is a small amount of adhesive lining the inside edges of the LCD screen. If you are having trouble prying off the screen, apply a small amount of heat to the front of the screen to melt the adhesive.
Abschluss
Ben DuBose
327 Reputation
3 Anleitungen geschrieben
Baylor, Team S2-G3, Johnson Spring 2018 Mitglied von Baylor, Team S2-G3, Johnson Spring 2018
BU-JOHNSON-S18S2G3
3 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 16
Insgesamt: 409
