Was du brauchst
Make sure the power is off by making sure the switch is to the right. The power switch can be found on the top side of the camera.
Use the Philips #00 Screwdriver on the screw on the left side of the camera.
There is another screw on the underside of the camera that is part of the left cover.
Use the Philips #00 Screwdriver to remove the two screws on the right cover of the camera.
Use the Philips #00 Screwdriver to remove the screws on the bottom side of the camera.
Make sure to grasp the camera because these are the last two screws that hold the camera in place.
Carefully place the opening tool between the two covers and gently apply force upward to separate the covers.
There are two digitizer cables that connect the LCD Screen to the camera motherboard.
The digitizer cables are held down by retaining flats.
Carefully use the opening tool to push the retaining flats upward to allow the digitizer cables to disconnect.
