Zum Hauptinhalt wechseln
Panasonic Lumix DMC-FX9 Selector Buttons Replacement
Was du brauchst
  1. Panasonic Lumix DMC-FX9 Selector Buttons Replacement, Selector Buttons: Schritt 1, Bild 1 von 1
    • Make sure the power is off by switching the power switch to the left.
  2. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 2, Bild 1 von 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 2, Bild 2 von 2
    • Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
  3. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 3, Bild 1 von 1
    • Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
  4. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 4, Bild 1 von 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 4, Bild 2 von 2
    • Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
    • Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
  5. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 5, Bild 1 von 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 5, Bild 2 von 2
    • Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
    • Remove the LCD Screen from the glass frame carefully with the opening tool.
  6. Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 6, Bild 1 von 2 Panasonic Lumix DMC-FX9 Selector Buttons Replacement: Schritt 6, Bild 2 von 2
    • Push on the back panel buttons on the front side to remove the buttons.
    • Be cautious of the adhesive holding the button panels to the cover. Apply extra force if necessary.
Abschluss
Kriselle Tubongbanua
133 Reputation
1 Anleitung geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 5
Letzte 30 Tage: 18
Insgesamt: 271
