Was du brauchst
Make sure the power is off by switching the power switch to the left.
Use a Phillips #00 screwdriver to remove the screws on the left side of the camera.
Remove the screws on the right side of the camera by using the Philips #00 screwdriver.
Remove the screws on the bottom side of the camera using the Philips #00 Screwdriver.
Separate the covers by gently applying force upwards, carefully placing the opening tool between the two covers.
Lift the ZIF tabs up with the opening tool and carefully remove the digitizer ribbon cables.
Remove the LCD Screen from the glass frame carefully with the opening tool.
