Einleitung
If your camera begins malfunctioning, you may need to replace your motherboard. In this replacement guide you will first remove the battery to avoid getting shocked while working inside the camera. Then you will remove the back panel, unscrew several screws, and detach several electronic ZIF connector ribbons to replace the motherboard. See this technique on disconnecting ZIF connectors to better learn how to detach a ZIF connector ribbon.
Was du brauchst
Slide the switch on the bottom of your camera from the right (LOCK) to the left (OPEN).
Push in on the SD card inside the battery housing.
Pull out the SD card.
Close the battery housing door.
Remove the two 5.2 mm Phillips #00 screws that are 1) below the label and 2) above the tripod mount hole on the bottom of the camera.
Remove the two 5.5 mm Phillips #00 screws on the side of the camera with the MIC jack.
Remove the two 7.0 mm Phillips #00 screws that are 1) above and 2) below the HDMI panel.
There are two screws that hold the eye piece on to the main housing, just underneath. Remove these. Once these have been removed, gently pull and remove the eye piece and remove the now accessible top two screws.
Gently lift up the back plate, being careful not to damage any ribbons.
Pull to disconnect from the motherboard the two ZIF connector ribbons attached to the back plate.
Set aside the back plate.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
Where do you buy a motherboard for this camera?
This article is useless, since the motherboards are not available anywhere.
Actually, Panasonic does have the part for sale. <https://panasonic.encompass.com/item/102...>
