Zum Hauptinhalt wechseln
Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement
Was du brauchst
  1. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: Schritt 1, Bild 1 von 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: Schritt 1, Bild 2 von 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement, Diopter Adjustment Dial: Schritt 1, Bild 3 von 3
    • Remove the four 4.6mm J000 Phillips screws from the sides and two 3.2mm J000 Phillips screws along the bottom.
  2. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 2, Bild 1 von 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 2, Bild 2 von 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 2, Bild 3 von 3
    • Remove the two 3.2mm J000 Phillips screws located on the bottom edge of the viewfinder cover.
    • Carefully remove the viewfinder cover.
    • Remove the two 4.4mm J000 Phillips screws located near the top edge of the viewfinder.
  3. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 3, Bild 1 von 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 3, Bild 2 von 3 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 3, Bild 3 von 3
    • Slide the Wide Plastic Opening Tool upwards along the underside of the rear casing.
    • Be careful not to disconnect the filament connections. Reinserting them can be difficult.
    • Slowly lower the casing into the position shown.
  4. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 4, Bild 1 von 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 4, Bild 2 von 2
    • Use the Screwdriver J000 Phillips Head to remove the screw located at the lower-left corner of the face of the viewfinder glass.
    • Carefully lift the L-shaped clicker underneath the previously removed screw.
  5. Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 5, Bild 1 von 2 Panasonic Lumix DMC-G5 Diopter Adjustment Dial Replacement: Schritt 5, Bild 2 von 2
    • Slide the faulty diopter adjustment dial off the rod.
    • Replace the diopter dial with a 1-cm wheel.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
USF Tampa, Team 1-3, Kass Spring 2017 Mitglied von USF Tampa, Team 1-3, Kass Spring 2017
USFT-KASS-S17S1G3
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 12
Insgesamt: 1,024
