Einleitung
Replacing the lens connection assembly requires partial removal of the front lens panel of the device, necessitating the removal of several small screws.
Was du brauchst
Remove the four 5.4 mm J000 screws from the front lens mount.
Use your hands or the thin plastic opening tool to remove the external housing ring as well as the smaller internal ring underneath.
Use the Thin Plastic Opening Tool to release the black connection ring.
Let the ring fall forward to reveal its underside.
Remove the two 2.7mm J000 phillips screws from the mount ring which connect to the ribbon of filament connections.
2 weitere Personen haben diese Anleitung absolviert.
