Einleitung
Panasonic Lumix DMC-G5 Motherboard replacement is required if the motherboard is damaged. This guide requires removal of several small screws and detachment of ribbon cables.
Was du brauchst
Remove the viewfinder lid.
Then, remove the two JIS #000 screws on the viewfinder.
Gently remove the back panel from the camera.
Unclip the ribbon cable from the motherboard using Wide Plastic Opening Tools and pull the cable gently.
Unclip the ribbon cable using the Wide Plastic Opening Tool on the motherboard.
Gently pull out the cable.
Ein Kommentar
Dear Khairul Samsudin - this is great, thank you so much.
Can I ask about another classic repair for the Lumix G5?
As with many lumix cameras, the rear thumbwheel on the Lumix G5 is a weak point and frequently fails - usually the “push in” movement that should change functions failes in the “pushed in” position.
Plese can you see if you can create a “fix” for this? It classically fails at about year 2-3, when the camera is out of warranty and the repairs cost from Panasonic is more than a secondhand G5 on eBay will cost!
Best wishes - Paul in the UK
