Einleitung
If the LCD panel has usability inhibiting number of dead pixels, or if the backlight comes on but no image is shown (or vice versa), then use the following guide to replace the LCD unit.
Was du brauchst
Unlock and open the battery compartment on the bottom of the camera.
Remove both the battery and SD card.
Remove the four indicated 3.0mm long black screws from the bottom of the camera and the viewfinder housing using a PH0 Phillips screwdriver.
Remove the four indicated 6.0mm long black screws using a PH0 Phillips screwdriver.
Remove the viewfinder eye cup by pulling up and out from the bottom to separate the locking clips from the camera.
Remove the two indicated silver 3.5mm long screws adjacent to the viewfinder screen using a PH0 Phillips screwdriver.
Use an iFixit opening tool (or similarly long and thin object) to insert into the gap between the two camera halves and pry the camera apart from the top.
Remove the two indicated ribbon cables before separating the two halves of the camera.
Using a flat object, pry open the black tabs above the ribbon cable connectors by gently pulling away from the motherboard.
On the inside half of the camera mounting the LCD, remove the two indicated 6.0mm black screws using a Phillips PH0.
On the back half (the side with the LCD panel), remove the indicated 3.0mm long silver screw on the hinge using a Phillips PH0.
On the hinge side of LCD panel housing itself, remove the two 4.0mm black screws indicated.
On the opposite end of the LCD panel housing, remove the two 2.5mm black screws.
Insert an iFixit Opening Pick (or guitar pick) into one of the long sides of the LCD panel and move it along the edge until you feel all three locking tabs disconnect.
Repeat the disconnection of locking tabs on the opposite side of the LCD panel.
One ribbon cable connects the display unit to the camera. Use an opening pick to pry the black tab open and then pull on the cable to disconnect it.
Two ribbon cables connect the LCD panel control board to the panel itself. Remove these the same way as the previous ribbon cable.
6 weitere Nutzer:innen haben diese Anleitung absolviert.
5 Kommentare
Hello, after owning my camera for 4 years, I dropped my camera and the screen went black. On and off switch works and the camera still makes shutter noises. I tried pressing the fn5 button thinking it was on the view finder but it did not work. Any help? thanks
Hi. I, having the same issue. LCD and View finder only show black screen. Camera does work and makes shutter noise (and saves pictures on SD kard) Did you solve your Problem?
Wonderful. I actually need to change the LCD display control main circuit board. Is that the piece of circuity stuck at the back of the LCD?
Thanks!
Really greatful for this post. G7 fixed!
Screen was loose, now fixed in 20 minutes, going to step 7. Yay! Rockstars.
