Einleitung
If the camera does not boot despite the battery being hail and hardy, there could be a fault on the main printed circuit board. Use the following guide to replace the main printed circuit board.
Was du brauchst
Unlock and open the battery compartment on the bottom of the camera.
Remove both the battery and SD card.
Remove the four indicated 3.0mm long black screws from the bottom of the camera and the viewfinder housing using a PH0 Phillips screwdriver.
Remove the four indicated 6.0mm long black screws using a PH0 Phillips screwdriver.
Remove the viewfinder eye cup by pulling up and out from the bottom to separate the locking clips from the camera.
Remove the two indicated silver 3.5mm long screws adjacent to the viewfinder screen using a PH0 Phillips screwdriver.
Use an iFixit opening tool (or similarly long and thin object) to insert into the gap between the two camera halves and pry the camera apart from the top.
Remove the two indicated ribbon cables before separating the two halves of the camera.
Using a flat object, pry open the black tabs above the ribbon cable connectors by gently pulling away from the motherboard.
Remove the 4 indicated flex cables from top of mainboard
Remove the indicated small flex cable from top of mainboard.
Remove the 4 indicated red 3.0mm long screws from the corners of mainboard using a Phillips PH0 screwdriver.
With the eyepiece facing away from you, pull up on the main PCB from the left side and then pull it away from the chassis.
There is a plastic locking tab on the bottom of the camera that holds the mainboard PCB.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
2 Kommentare
Hi I had an issue with my camera’s SD card slot and I disassembled to look why it wasn’t reading SD cards and found an issue and I think I fixed it, but when I assembled it it won’t turn on now. Do you have any advice on figuring out what is causing it to not turn on? I checked all flex cables and they seem to be connected. Any help is appreciated!
Im having the same issue. Did you fix it?
