Zum Hauptinhalt wechseln
Panasonic Lumix DMC-GF2 Front Cover Replacement
Was du brauchst
  1. Panasonic Lumix DMC-GF2 Front Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • On the bottom of the camera, use your finger to push the lock button to the open position which will cause the hinged door to swing open.
  2. Panasonic Lumix DMC-GF2 Front Cover Replacement: Schritt 2, Bild 1 von 2 Panasonic Lumix DMC-GF2 Front Cover Replacement: Schritt 2, Bild 2 von 2
    • Push the small black tab that holds the battery with your finger to release the battery.
    • Use your fingers to pull the battery out of the camera.
  3. Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: Schritt 3, Bild 1 von 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: Schritt 3, Bild 2 von 3 Panasonic Lumix DMC-GF2 Front Cover Replacement, Front Cover: Schritt 3, Bild 3 von 3
    • Using a Philips #00 screwdriver, remove six 2.69 mm screws located on the two short sides and on the bottom of the camera.
    • To loosen a screw, turn the screwdriver to the left. To tighten a screw, turn the screwdriver to the right.
  4. Panasonic Lumix DMC-GF2 Front Cover Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips #00 screwdriver, remove four black 2.69 mm screws from the front of the camera.
  5. Panasonic Lumix DMC-GF2 Front Cover Replacement: Schritt 5, Bild 1 von 1
    • Using your hand, gently lift up the front cover and separate it from the camera.
Abschluss
Baylor, Team 5-9, Williams Fall 2016 Mitglied von Baylor, Team 5-9, Williams Fall 2016
BU-WILLIAMS-F16S5G9
3 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 14
Insgesamt: 1,039
