Einleitung
Step by step guide to replacing your digital camera door.
Was du brauchst
Remove the battery and memory card from the unit
Remove 6 (0.3mm) screws from the sides of the unit
Remove 5 (0.3mm) screws from the bottom of the unit
Lift up slightly the rear cover.
Flip up the cable clamps using a spudger or other device. Careful not to break the clamps. Release flex cables and remove back cover.
Pull out door pin using needle nose pliers or other tool.
Notice spring positioning. This will help you re-install your replacement door
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
