Einleitung
Step by step guide to replacing your damaged LCD Display
Was du brauchst
Remove the battery and memory card from the unit
Remove 6 (0.3mm) screws from the sides of the unit
Remove 5 (0.3mm) screws from the bottom of the unit
Lift up slightly the rear cover.
Flip up the cable clamps using a spudger or other device. Careful not to break the clamps. Release flex cables and remove back cover.
Fast fertig!
Abschluss
