Zum Hauptinhalt wechseln
Panasonic Lumix DMC-ZS25 Power Button Replacement
Was du brauchst
  1. Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: Schritt 1, Bild 1 von 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: Schritt 1, Bild 2 von 3 Panasonic Lumix DMC-ZS25  Power Button Replacement, Unscrewing your Panasonic Lumix: Schritt 1, Bild 3 von 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to open the outer cover of your device.
    • The easiest place to open your device is from the HDMI port.
    • Open it gently to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 3, Bild 1 von 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 3, Bild 2 von 2
    • Use a spudger to detach the ribbon cable.
    • Be careful when you use the spudger because you do not want to break the the ribbon.
  4. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 4, Bild 1 von 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 4, Bild 2 von 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 4, Bild 3 von 3
    • Remove the button board using the plastic opening tool.
    • Remove the screen. Lift the screen from the right hand side.
    • After your hear a "click" sound, you have successfully opened the screen.
  5. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 5, Bild 1 von 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 5, Bild 2 von 2
    • Remove the two black screws that are located beneath the screen.
    • Lift the metal cover using the plastic opening tool.
  6. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 6, Bild 1 von 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 6, Bild 2 von 2
    • Use the plastic opener to remove the side covers.
  7. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 7, Bild 1 von 2 Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 7, Bild 2 von 2
    • After removing the side covers, you will be able to take away the front cover with your hands.
    • Do not apply too much pressure on the outer cover of your device to avoid damage.
  8. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 8, Bild 1 von 1
    • To release the top cover of the camera, you need to open the 3.70 mm screw shown in the picture.
  9. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 9, Bild 1 von 1
    • Remove the top cover using the plastic opening tool.
  10. Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 10, Bild 1 von 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 10, Bild 2 von 3 Panasonic Lumix DMC-ZS25  Power Button Replacement: Schritt 10, Bild 3 von 3
    • After removing the top cover of the camera, you will be able to easily remove the power button with your hand.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Abbas Khan
482 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 9-5, Brown Winter 2015 Mitglied von USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 8
Insgesamt: 578
