Zum Hauptinhalt wechseln
Panasonic Lumix DMC-ZS25 Screen Replacement
Was du brauchst
  1. Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: Schritt 1, Bild 1 von 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: Schritt 1, Bild 2 von 3 Panasonic Lumix DMC-ZS25  Screen Replacement, Screen: Schritt 1, Bild 3 von 3
    • Open the four 3.40 mm screws from the right and left sides of your Panasonic Lumix Camera.
    • Remove the two 2.60 mm screws located next to the battery.
  2. Panasonic Lumix DMC-ZS25  Screen Replacement: Schritt 2, Bild 1 von 1
    • Use the plastic opening tool to open the outer cover of your device from the HDMI port.
    • Open it carefully to avoid breaking the cover.
  3. Panasonic Lumix DMC-ZS25  Screen Replacement: Schritt 3, Bild 1 von 3 Panasonic Lumix DMC-ZS25  Screen Replacement: Schritt 3, Bild 2 von 3 Panasonic Lumix DMC-ZS25  Screen Replacement: Schritt 3, Bild 3 von 3
    • Use a spudger to carefully detach the ribbon cable without breaking it.
  4. Panasonic Lumix DMC-ZS25  Screen Replacement: Schritt 4, Bild 1 von 1
    • Use the plastic opening tool to lift and remove the buttons board as shown.
  5. Panasonic Lumix DMC-ZS25  Screen Replacement: Schritt 5, Bild 1 von 2 Panasonic Lumix DMC-ZS25  Screen Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift the screen using the plastic opening tool as shown.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Abbas Khan
482 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 9-5, Brown Winter 2015 Mitglied von USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
- Of the two 2.60 mm screws on the bottom of the camera, only the one closest to the back needs to be removed.
- The correct screwdriver is JIS Type S #00. A Phillips driver can ruin the screws.
- The screen shown in step 5 consists of two parts: the LCD and a frame. The replacement LCD that I ordered came without the frame, so a little more disassembly was required, including a bit of delicate soldering: the narrow ribbon cable is really two cables, soldered together. The solder joints are hidden under the piece of black electric tape at the end.
nasorenga - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 8
Letzte 30 Tage: 10
Insgesamt: 4,374
