Zum Hauptinhalt wechseln
Panasonic Lumix DMC-ZS25 Flash Replacement
Was du brauchst
  1. Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: Schritt 1, Bild 1 von 2 Panasonic Lumix DMC-ZS25 Flash Replacement, Flash: Schritt 1, Bild 2 von 2
    • Using a small screwdriver, remove the four 3.4mm screws from the right and left sides of your Panasonic Lumix Camera.
  2. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 2, Bild 1 von 1
    • Using a small screwdriver, remove the two 2.6mm screws located next to the battery, on the outer casing.
  3. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 3, Bild 1 von 1
    • Using the plastic opening tool, open the outer cover of your device.
    • The easiest way to open your device is by placing the tool in the HDMI port.
  4. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 4, Bild 1 von 3 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 4, Bild 2 von 3 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 4, Bild 3 von 3
    • Using the spudger, pull upward on the screen cable to release it.
  5. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 5, Bild 1 von 1
    • Using the plastic opening tool, lift the button board until it clicks.
  6. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 6, Bild 1 von 2 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 6, Bild 2 von 2
    • Using the plastic opening tool, lift the screen until it clicks.
  7. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 7, Bild 1 von 1
    • Using a small screwdriver, remove the two 4.2mm screws located on the corner of the inner cover, under the screen.
  8. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 8, Bild 1 von 1
    • Using the plastic opening tool, remove the inner cover.
  9. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 9, Bild 1 von 2 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 9, Bild 2 von 2
    • Using your hands or the opening tool, separate the device into two pieces, as shown.
  10. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 10, Bild 1 von 2 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 10, Bild 2 von 2
    • Using the spudger, remove the black side cover.
  11. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 11, Bild 1 von 1
    • Using your hands, remove the front cover.
  12. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 12, Bild 1 von 3 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 12, Bild 2 von 3 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 12, Bild 3 von 3
    • Using the spudger, unlock the screen cables from the circuit board.
    • Lift up the black clip to release the cables.
  13. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 13, Bild 1 von 1
    • Using your hands, remove the lens.
  14. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 14, Bild 1 von 1
    • Using the plastic opening tool, pull up on the edge of the circuit board until it clicks.
    • Remove the board.
  15. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 15, Bild 1 von 1
    • Using a small screwdriver, remove the 3.7 mm screw near the green chip inside the camera, as shown. This will release the top of the camera.
  16. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 16, Bild 1 von 3 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 16, Bild 2 von 3 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 16, Bild 3 von 3
    • Using the opening tool, pull up on the edge of the top cover to unlock it.
  17. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 17, Bild 1 von 2 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 17, Bild 2 von 2
    • Using the opening tool, remove the top board.
  18. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 18, Bild 1 von 2 Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 18, Bild 2 von 2
    • Place the tip of the spudger at the edge of the top board, and work around three sides to loosen it.
    • Using the opening tool, lift up the top board. Now you will be able to safely remove the flash.
  19. Panasonic Lumix DMC-ZS25 Flash Replacement: Schritt 20, Bild 1 von 1
    • Remove the old flash, and put in the replacement.
Abschluss
Abbas Khan
482 Reputation
4 Anleitungen geschrieben
USF Tampa, Team 9-5, Brown Winter 2015 Mitglied von USF Tampa, Team 9-5, Brown Winter 2015
USFT-BROWN-W15S9G5
3 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 15
Insgesamt: 415
