Ersatzteile
Kein Ersatzteil erforderlich.
  1. Remove the following eleven screws securing the covers to the ZS3 Eleven 3 mm Phillips screws Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
    • Remove the following eleven screws securing the covers to the ZS3
      • Eleven 3 mm Phillips screws
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown. Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Erfolgreich repariert? Genial!
    Teile ein Foto deiner Reparatur mit dem Hashtag #ImAGenius
    Wir sind alle Genies
  4. Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit. Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  5. Remove the two LCD board ribbon cables out of their sockets.
    • Remove the two LCD board ribbon cables out of their sockets.
  6. Use the flat end of the spudger to gently pry the buttons from the back panel. Remove the buttons in three pieces, starting with the top left one, then moving to one next to it. Once this is finished remove the rest of the buttons. The buttons are attached to the back cover using adhesive, and this may need to be reapplied to put them back on.
    • Use the flat end of the spudger to gently pry the buttons from the back panel.
      • Remove the buttons in three pieces, starting with the top left one, then moving to one next to it. Once this is finished remove the rest of the buttons.
      • The buttons are attached to the back cover using adhesive, and this may need to be reapplied to put them back on.
Abschluss
Cal Poly, Team 13-60, Johann Spring 2013 Mitglied von Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 Mitglieder
5 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 3
Insgesamt: 391
