Zum Hauptinhalt wechseln
Panasonic Lumix DMC-ZS3 Lens Replacement
Was du brauchst
  1. Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: Schritt 1, Bild 1 von 3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: Schritt 1, Bild 2 von 3 Panasonic Lumix DMC-ZS3 Lens Replacement, Back Cover: Schritt 1, Bild 3 von 3
    • Remove the eleven 3 mm screws securing the covers to the ZS3.
    • Using too much pressure when removing the screws may strip the screws and complicate screw removal at a later time.
  2. Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 2, Bild 1 von 2 Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 2, Bild 2 von 2
    • Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
    • Be sure to carefully and slowly lift the back cover. Forcefully lifting the back cover and fully separating it at this point may ruin internal connections.
  3. Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 3, Bild 1 von 2 Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 3, Bild 2 von 2
    • Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
    • Be sure you are opening the locking tab, not pulling against the socket mounted to the board.
  4. Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 4, Bild 1 von 1
    • Remove the two LCD board ribbon cables out of their sockets.
  5. Panasonic Lumix DMC-ZS3 Lens Replacement, Lens: Schritt 5, Bild 1 von 1
    • Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
  6. Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 6, Bild 1 von 3 Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 6, Bild 2 von 3 Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 6, Bild 3 von 3
    • Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
    • The LCD ribbon cables connect the back cover to the rest of the unit.
    • Use the spudger to disconnect the LCD ribbons.
  7. Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 7, Bild 1 von 3 Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 7, Bild 2 von 3 Panasonic Lumix DMC-ZS3 Lens Replacement: Schritt 7, Bild 3 von 3
    • Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
    • Excessive force may damage the camera. Be sure to lift the lens slowly and carefully to avoid damage to other parts.
    • Unlock lens mechanism located on the bottom of the device using your fingers.
Abschluss
Cal Poly, Team 13-60, Johann Spring 2013 Mitglied von Cal Poly, Team 13-60, Johann Spring 2013
CPSU-JOHANN-S13S13G60
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 14
Insgesamt: 3,442
