Einleitung
You may need to replace or clean your Panasonic Lumix DMC-ZS40 Camera Sensor if splotches/dirt are appearing in your photos, or if the LCD screen remains black when attempting to take photos.
Was du brauchst
Find the battery/memory card door on the bottom right of the camera.
Use your finger or screw driver to slide the grey latch from the locked position to the open position. This will swing open the door.
Unscrew these five 3mm screws located around the sides of the camera using a screw driver with a PH000 bit head.
Remove these four 4mm screws and the 3mm screw on the top of the plate cover and on the side of the camera using a PH000 bit head. Once the screws are removed, the plate cover should lift right up.
Using the T3 Phillips Screwdriver, unscrew the three Torx T3 2.5mm screws holding the sensor down.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ein Kommentar
After the CCD is replaced, how do you adjust the 3 torx screws, so the ccd is in alignment? After the replacement the right side of my pictures are out of focus.
