Zum Hauptinhalt wechseln
Panasonic Lumix DMC-ZS6 Lens Assembly Replacement
Was du brauchst
  1. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement, Lens Assembly: Schritt 1, Bild 1 von 1
    • Remove the battery and the SD Card.
  2. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 2, Bild 1 von 3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 2, Bild 2 von 3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 2, Bild 3 von 3
    • Unscrew the two bottom 1.0 mm screws with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the left with a Phillips #000 screwdriver.
    • Unscrew the two 1.0 mm screws to the right with a Phillips #000 screwdriver.
  3. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 3, Bild 1 von 1
    • Carefully separate the back of the camera from the main body.
    • Do not apply excessive force. The LCD is connected by ribbon cables that can be easily damaged.
  4. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 4, Bild 1 von 2 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 4, Bild 2 von 2
    • Use the tip of the 2.0 mm flathead screwdriver to flip up the black tabs on the ribbon cables.
    • Pull gently on the ribbon cables to unseat them.
  5. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 5, Bild 1 von 3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 5, Bild 2 von 3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 5, Bild 3 von 3
  6. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 6, Bild 1 von 1
    • Carefully separate the front of the camera from the main body.
  7. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 7, Bild 1 von 2 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 7, Bild 2 von 2
    • Use the tip of the 1.5 mm flathead screwdriver to disengage the plastic tab.
    • Carefully lift the selector switch away from the motherboard.
  8. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 8, Bild 1 von 2 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 8, Bild 2 von 2
    • Unscrew the three silver 1.0 mm screws with a Phillips #000 screwdriver.
    • Use the tip of the 2.0 mm flathead to disengage the metal tab, then carefully lift the shield away from the motherboard.
  9. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 9, Bild 1 von 1
    • Insert the tip of the 2.0 mm flathead into the center hole of the tripod mount, and apply force in the direction facing away from the button.
    • Carefully lift the tripod mount out of the camera body.
  10. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 10, Bild 1 von 2 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 10, Bild 2 von 2
    • Use the 2.0 mm flathead to flip up the brown tab on the motherboard and carefully unseat the ribbon cable.
    • Insert the tip of the 2.0 mm flathead screwdriver into the hole on the daughterboard, then apply upward force to remove the daughterboard from the main case.
  11. Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 11, Bild 1 von 3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 11, Bild 2 von 3 Panasonic Lumix DMC-ZS6 Lens Assembly Replacement: Schritt 11, Bild 3 von 3
    • Use the 2.0 mm flathead to flip up the two tabs on the motherboard and carefully unseat the ribbon cables.
    • Carefully lift the lens assembly out of the camera.
Abschluss
Derrick Thompson
1.035 Reputation
5 Anleitungen geschrieben
Baylor, Team S2-G5, Johnson Spring 2018 Mitglied von Baylor, Team S2-G5, Johnson Spring 2018
BU-JOHNSON-S18S2G5
3 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 2
Letzten 30 Tage: 9
Insgesamt: 393
