Zum Hauptinhalt wechseln
Panasonic Lumix DMC-ZS60 LCD Screen Replacement
Was du brauchst
  1. Panasonic Lumix DMC-ZS60 LCD Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Use your finger to slide the black latch from the locked position to the open position on the memory card/battery door. This will open the door of the camera.
  2. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Push up the black tab on the right-hand-side to spring release the battery.
  3. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery by sliding it out from the camera.
  4. Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 2 von 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 3 von 3
    • Using the Phillips #000 Screwdriver, unscrew six 3mm screws. There are two screws located on three sides excluding the top.
  5. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Pry off back casing and set aside.
  6. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • Pull the right side control dial circuit board up.
    • Use tweezers to pry up the white retaining flap and gently pull the circuit board out.
  7. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 7, Bild 1 von 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 7, Bild 2 von 3 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • Flip the LCD screen to the left.
    • Unscrew the two 3mm on the top right side using the Phillips #000 Screwdriver.
    • Lift the gray plate cover off.
  8. Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 8, Bild 1 von 2 Panasonic Lumix DMC-ZS60 LCD Screen Replacement: Schritt 8, Bild 2 von 2
    • Use tweezers to pry up the black retaining flat and gently pull to free the LCD screen from the device.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 9
Insgesamt: 369
