Zum Hauptinhalt wechseln
Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement
Was du brauchst
  1. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: Schritt 1, Bild 1 von 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: Schritt 1, Bild 2 von 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement, Mounting Bracket: Schritt 1, Bild 3 von 3
    • Remove the side panels by unscrewing the Phillips head screws on both sides of the camera.
  2. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 2, Bild 1 von 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 2, Bild 2 von 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 2, Bild 3 von 3
    • Remove the back panel by unscrewing the two Phillips head screws on the bottom of the camera towards the back.
    • Lift the back panel from the camera and set it aside.
  3. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 3, Bild 1 von 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 3, Bild 2 von 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 3, Bild 3 von 3
    • Unscrew the Phillips head screw shown in the picture to remove the front panel.
    • Remove the front panel to expose the bracket at the bottom of the camera.
  4. Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 4, Bild 1 von 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 4, Bild 2 von 3 Panasonic Lumix DMC-ZS8 Mounting Bracket Replacement: Schritt 4, Bild 3 von 3
    • Pry the right side of the bracket up to allow you to grab the bracket with tweezers.
    • Grab the bracket with tweezers and slide it toward the battery door to remove it from the frame of the camera.
Abschluss
Trevor Meyers
356 Reputation
2 Anleitungen geschrieben
Sam Houston State, Team 13-13, Blackburne Spring 2015 Mitglied von Sam Houston State, Team 13-13, Blackburne Spring 2015
SHSU-BLACKBURNE-S15S13G13
4 Mitglieder
10 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 6
Insgesamt: 301
