Einleitung
Is your camera not turning on? A quick battery replacement may solve your problem.
Was du brauchst
Turn the camera off and identify the battery door located on the bottom of the camera.
To release the battery, slide the white release lever next to the SD card slot.
The battery should now be released; you may now remove the battery from the camera body.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
