Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
How to fix squeaky water flow
Ersatzteile
Keine Ersatzteile angegeben.
  1. Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull Shake it a litlle so the tube can get out here.
    • Warning: Bevore working at it unplug the power. Here you can see the plastic tube from where the water comes out. it is clipped in a clear plastic shape. Open the clips and pull
    • Shake it a litlle so the tube can get out here.
    • This clear plastic is fragile,
    • be careful with it or the clipse may break.
  2. More pictures, look. you can clean it with citric acid. you can clean it with citric acid.
    • More pictures, look.
    • you can clean it with citric acid.
  3. SPAR DIR DAS UPGRADE
    Mach dein iPhone so gut wie neu mit unseren Fix Kits.
    Jetzt entdecken
    Jetzt entdecken
  4. How to open. First remove two PH2 screws left and right. PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted. Now pull it downwards. Now turn around and you see the plastic from the lever.
    • How to open. First remove two PH2 screws left and right.
    • PULL the complete display. Shake it a little because the flap of the ice-crusher could be frosted.
    • Now pull it downwards. Now turn around and you see the plastic from the lever.
  5. This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
    • This is the backside: The quadratic black rubber part is a motorized flap of the ice-crusher, be careful with it, there are fragile springs, dont loose them.
    • Now spray some SILICONE_SPRAY on the moving parts, i made some red circles for it. Just a little bit, also on the springs.
    • TRY, move it, now the noise should gone, whiole moving it.
    • Thats it, reassemble it, be careful with the notches and clipse.
    • done. :)
Abschluss
easy
2 weitere Nutzer haben diese Anleitung absolviert.
Besonderer Dank geht an diese Übersetzer:
100%
Schwarzstein hilft uns, die Welt in Ordnung zu bringen! Wie kann ich mithelfen?
Beginne zu übersetzen ›
Schwarzstein
2.445 Reputation
14 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 5
Letzten 30 Tage: 37
Insgesamt: 1,066
