Zum Hauptinhalt wechseln
Panasonic RQ-2102 Battery Replacement
Was du brauchst
  1. Panasonic RQ-2102 Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Open the battery compartment by pressing down on the small tab along the upper edge of battery cover.
  2. Panasonic RQ-2102 Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the old batteries one at a time.
    • If batteries do not come out or are rusted, remove carefully with a prying tool. If rusty or dirty, clean compartment and contacts with a dry towel.
  3. Panasonic RQ-2102 Battery Replacement: Schritt 3, Bild 1 von 2 Panasonic RQ-2102 Battery Replacement: Schritt 3, Bild 2 von 2
    • Insert the new working batteries in the order listed in the diagram on the back of the device.
    • Both batteries in a single row should be facing the same direction and make contact + to -.
  4. Panasonic RQ-2102 Battery Replacement: Schritt 4, Bild 1 von 1
    • Put the battery cover back onto the device.
Ziellinie
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 20
Insgesamt: 948
