Zum Hauptinhalt wechseln
Panasonic RQ-2102 Holding Handle Replacement
Was du brauchst
  1. Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: Schritt 1, Bild 1 von 3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: Schritt 1, Bild 2 von 3 Panasonic RQ-2102 Holding Handle Replacement, Holding Handle: Schritt 1, Bild 3 von 3
    • Remove the three M5-0.8 x 12 mm Phillips #0 screws from the back of the device body.
    • There are two more screws inside the battery compartment. Remove those as well.
    • Cautiously remove the back of the device body. Be sure not to damage the cord that connects the two sides.
    • All of the screws are the same size.
  2. Panasonic RQ-2102 Holding Handle Replacement: Schritt 2, Bild 1 von 2 Panasonic RQ-2102 Holding Handle Replacement: Schritt 2, Bild 2 von 2
    • Carefully remove the handle. Make sure the handle catches on each side are intact.
    • Replace the old handle with the new handle.
    • Remember, if the handle catches are broken, the device must be replaced.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 12
Insgesamt: 593
