Zum Hauptinhalt wechseln
Panasonic SA-HT810V VHS Drive Replacement
Was du brauchst
  1. Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: Schritt 1, Bild 1 von 3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: Schritt 1, Bild 2 von 3 Panasonic SA-HT810V VHS Drive Replacement, VHS Drive: Schritt 1, Bild 3 von 3
    • With the front display of the device facing you, rotate the device 90 degrees counter clockwise.
    • Now rotate the device 180 degrees and remove the second screw.
    • Remove the screw that is on the right side of the panel facing you.
    • All screws will need to be removed with a phillips head screwdriver.
  2. Panasonic SA-HT810V VHS Drive Replacement: Schritt 2, Bild 1 von 2 Panasonic SA-HT810V VHS Drive Replacement: Schritt 2, Bild 2 von 2
    • Rotate the device so that the back faces you.
    • With a phillips heat screwdriver, locate and remove the four screws highlighted by the red circles in image one.
  3. Panasonic SA-HT810V VHS Drive Replacement: Schritt 3, Bild 1 von 1
    • Before removing cover make sure that the back of the device is facing you.
    • Remove the top cover by bending out on the sides, and pulling the cover towards you while applying upward pressure.
  4. Panasonic SA-HT810V VHS Drive Replacement: Schritt 4, Bild 1 von 3 Panasonic SA-HT810V VHS Drive Replacement: Schritt 4, Bild 2 von 3 Panasonic SA-HT810V VHS Drive Replacement: Schritt 4, Bild 3 von 3
    • Pull up the two tabs on top
    • Pull the the three tabs on the side there is one on the left and two and the right side of the device when it is facing you.
    • Depress the four tabs on the bottom of the device.
  5. Panasonic SA-HT810V VHS Drive Replacement: Schritt 5, Bild 1 von 1
    • Carefully pull off the front panel of the device.
    • The front is attached to the device with cables so be careful when removing.
  6. Panasonic SA-HT810V VHS Drive Replacement: Schritt 6, Bild 1 von 2 Panasonic SA-HT810V VHS Drive Replacement: Schritt 6, Bild 2 von 2
    • With the device front facing you remove the six screws with a phillips head screwdriver around the VHS drive.
  7. Panasonic SA-HT810V VHS Drive Replacement: Schritt 7, Bild 1 von 1
    • Remove the three cables attaching the VHS to the Mother Board.
    • Carefully pull the VHS drive out of the device and follow the steps in reverse to place the new one in.
    • Make sure the cables connecting the VHS Drive are fully inserted before powering the machine on to prevent damage to the internal components.
Abschluss
Cal Poly, Team 16-5, Maness Spring 2010 Mitglied von Cal Poly, Team 16-5, Maness Spring 2010
CPSU-MANESS-S10S16G5
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 1,024
