Zum Hauptinhalt wechseln
Panasonic SA-PM17 CD Tray Cover Replacement
Was du brauchst
  1. Panasonic SA-PM17 CD Tray Cover Replacement, Disassembling front of the Panasonic SA-PM17: Schritt 1, Bild 1 von 2 Panasonic SA-PM17 CD Tray Cover Replacement, Disassembling front of the Panasonic SA-PM17: Schritt 1, Bild 2 von 2
    • Using a Phillips screwdriver, remove the eight 9.5 mm screws on the left and right sides of the device.
    Frag FixBot
    Kommentar hinzufügen
  2. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 2, Bild 1 von 1
    • Remove these seven 11.5 mm screws and place aside.
    Frag FixBot
  3. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 3, Bild 1 von 1
    • Lift the right side off of the device and place aside.
    • Repeat for left side.
    Frag FixBot
  4. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 4, Bild 1 von 1
    • Lift the top gently but firmly from the back of the device. Allow it to rest on the back without reattaching it.
    • Do not pull the top too far as there are wires attached to it.
    Frag FixBot
  5. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 5, Bild 1 von 2 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 5, Bild 2 von 2
    • Gently lift up on the indicated tabs to disengage them from the hooks holding them in place.
    Frag FixBot
  6. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 6, Bild 1 von 1
    • Lift up the top while firmly sliding it towards the back of the device.
    • Do not lift the top up too high as there are cords that need to be detached before the top can be removed.
    • The next step is a zoom-in of the indicated area.
    Frag FixBot
  7. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 7, Bild 1 von 1
    • Using forceps or fingers, remove the small black wire indicated.
    • Grip the wire near its base and pull gently but firmly until it pops out of the slot.
    Frag FixBot
  8. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 8, Bild 1 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 8, Bild 2 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 8, Bild 3 von 3
    In diesem Schritt verwendetes Werkzeug:
    • This step deals with the indicated area of the device.
    • Using fingers or tweezers, lift the indicated tabs out until the cord's restraint looks like the final picture.
    • Gently pull on the cord near its base until it comes free of the restraint.
    Frag FixBot
  9. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 9, Bild 1 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 9, Bild 2 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 9, Bild 3 von 3
    • Lift the indicated tabs out until the restraint looks like the final picture.
    • Gently pull on the cord until it comes free of the attachment.
    • The top section of the device should now be free of the body. Place it aside in a safe place.
    Frag FixBot
  10. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 10, Bild 1 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 10, Bild 2 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 10, Bild 3 von 3
    • This step deals with the indicated portion of the the device.
    • Lift the indicated tabs out until they look like the final picture.
    • Gently pull on the cord until it comes free of its restraint.
    Frag FixBot
  11. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 11, Bild 1 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 11, Bild 2 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 11, Bild 3 von 3
    • Neither of the indicated cords have restraints on them like the previous ones. Use tweezers or fingers to pull firmly on the base of each cord until it comes free.
    Frag FixBot
  12. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 12, Bild 1 von 2 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 12, Bild 2 von 2
    • Use tweezers or fingers and firmly pull straight out on the cord until it comes free.
    Frag FixBot
  13. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 13, Bild 1 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 13, Bild 2 von 3 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 13, Bild 3 von 3
    • Using tweezers or fingers, lift gently on the tab indicated to free the front from the body of the device.
    • Rotate device 180 degrees and repeat for other side.
    • Rotate the front slightly forward to keep the tabs from re-engaging on their hooks.
    Frag FixBot
  14. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 14, Bild 1 von 1
    • Wiggle the front gently while pulling it forward until it comes free of the body of the device.
    Frag FixBot
  15. Panasonic SA-PM17 CD Tray Cover Replacement, CD Tray Cover: Schritt 15, Bild 1 von 1
    • Remove the two 11.5 mm screws indicated and set aside in a safe place.
    Frag FixBot
  16. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 16, Bild 1 von 2 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 16, Bild 2 von 2
    • Using tweezers, remove the two restraints indicated and place with the screws removed in the previous step.
    Frag FixBot
  17. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 17, Bild 1 von 2 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 17, Bild 2 von 2
    • Remove the spring from its slot using tweezers.
    Frag FixBot
  18. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 18, Bild 1 von 1
    • Using tweezers or fingers, pull firmly on the base of this cord until it pops out of its slot.
    Frag FixBot
  19. Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 19, Bild 1 von 2 Panasonic SA-PM17 CD Tray Cover Replacement: Schritt 19, Bild 2 von 2
    • Lift the pegs of the cover up while rotating the rest of the part down and out of the device.
    • If at first the cover does not come free, wiggle it around a bit until it does, but do not force it out.
    • Do not to lose this spring while replacing the cover.
    Frag FixBot
Abschluss
NathanB
418 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 4-1, Regan Spring 2011 Mitglied von Cal Poly, Team 4-1, Regan Spring 2011
CPSU-REGAN-S11S4G1
3 Mitglieder
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 7
Letzte 30 Tage: 35
Insgesamt: 5,443
