Zum Hauptinhalt wechseln
Einleitung
This guide provides the steps to remove the back cover. This process is necessary to access many of the components inside.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Panasonic Toughbook CF-29 Back Cover Replacement, Battery: Schritt 1, Bild 1 von 1
    • Locate the bay door for the battery on the left side of the laptop.
  2. Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 2, Bild 1 von 2 Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 2, Bild 2 von 2
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Panasonic Toughbook CF-29 Back Cover Replacement, Optical Drive: Schritt 3, Bild 1 von 1
    • Flip the device upside down with the handle facing away from you.
    • Open the optical drive bay by sliding its latch to the right.
    • Locate optical drive release mechanism on the bottom of the laptop.
  4. Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 4, Bild 1 von 1
    • Slide the latch cover to the right.
  5. Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 5, Bild 1 von 2 Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 5, Bild 2 von 2
    • Push the exposed switch to the left to eject the optical drive.
  6. Panasonic Toughbook CF-29 Back Cover Replacement, Back Cover: Schritt 6, Bild 1 von 1
    • Begin by turning the laptop upside down with the handle towards you.
    • Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
  7. Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 7, Bild 1 von 1
    • Remove the panel and set it aside.
    • Use a Phillips size 0 screwdriver to remove these 8 small screws.
  8. Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 8, Bild 1 von 1
    • Use a Phillips size 1 screwdriver to remove the remaining 8 screws.
  9. Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 9, Bild 1 von 2 Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 9, Bild 2 von 2
    • Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
  10. Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 10, Bild 1 von 1
    • Be careful when lifting the cover as you may damage some connections.
    • Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
  11. Panasonic Toughbook CF-29 Back Cover Replacement: Schritt 11, Bild 1 von 1
    • Now the back cover should be off and you can access the inside of the casing.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Rohun Heesen
387 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 27-93, Amido Spring 2010 Mitglied von Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Mitglieder
24 Anleitungen geschrieben
Ein Kommentar
thanks for this crucial tuatorial >
Joe Gutierrez - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 25
Insgesamt: 9,828
