Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Store
Einleitung
This guide will show you how to safely remove the hard drive from your laptop.
  1. Locate the bay door for the battery on the left side of the laptop.
    • Locate the bay door for the battery on the left side of the laptop.
  2. Slide the latch to the right and then down to unlock it. Pull out the battery.
    • Slide the latch to the right and then down to unlock it.
    • Pull out the battery.
  3. Locate the door for the hard drive on the right side of the laptop
    • Locate the door for the hard drive on the right side of the laptop
  4. Push and slide the latch up to open the hard drive door. Pull out the hard drive.
    • Push and slide the latch up to open the hard drive door.
    • Pull out the hard drive.
Abschluss
2 weitere Nutzer haben diese Anleitung absolviert.
Clint Kirsop
73 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 27-93, Amido Spring 2010 Mitglied von Cal Poly, Team 27-93, Amido Spring 2010
CPSU-AMIDO-S10S27G93
4 Mitglieder
24 Anleitungen geschrieben
This guide is missing all the steps to remove the hard drive from the caddy. Here's a more complete guide: http://www.bobjohnson.com/how-to-replace...
Ed Lasher - Antwort
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 3
Letzten 30 Tage: 39
Insgesamt: 12,891
