Einleitung
This guide will provide you with step by step instructions to replace your Toughbook CF-29's speaker.
Was du brauchst
Begin by turning the laptop upside down with the handle towards you.
Use a Phillips size 0 screwdriver to remove the 4 screws holding down the ram cover.
Remove the panel and set it aside.
Use a Phillips size 0 screwdriver to remove these 8 small screws.
Use a plastic opening tool to release, but NOT remove, the back cover because it is sealed with adhesive.
Slowly lift the cover so that you can disconnect the red and white wires connecting the speaker to the sound card.
Place the back cover infront of you so you can access the inside of it.
Remove the 3 screws holding in the speaker.
Pry out the speaker using a flat screw driver or a blue pry tool. It is held in with an adhesive.
Your speaker is now removed
Put in your replacement by following the reverse steps.
