Einleitung
This guide will take you through the steps of removing the touchscreen.
Ersatzteile
Open the laptop and remove the four indicated screws with a Phillips size 0 screwdriver.
Pry off the plastic strip which was previously held in place by the screws.
Remove 16 screws from the top of the closed laptop.
12 Phillips size 1 screws
2 Phillips size 0 screws
2 Torx size 6 screws (T6)
Gently break the adhesive seal between the front and rear display cases with a plastic opening tool.
The top half of the case can be removed by sliding the tabs out from under the hinges.
This makes unplugging the screen wiring much easier
Remove the 3 strips of black tape as shown to reveal connections 2 and 3.
Pull the wiring for each away from the connections to remove.
Using a plastic opening tool, lift the screen as shown from the case and pull free.
5 weitere Nutzer haben diese Anleitung absolviert.
Ein Kommentar
This guide is good for replacing the LCD screen, but it is not complete for the touchscreen panel, which requires some more delicate and precise steps. I think the title of the guide needs to be changed.
Thanks
