Zum Hauptinhalt wechseln
Panasonic Toughbook CF-53 Hard Drive Replacement
Was du brauchst
  1. Panasonic Toughbook CF-53 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 1 von 3 Panasonic Toughbook CF-53 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 2 von 3 Panasonic Toughbook CF-53 Hard Drive Replacement, Hard Drive: Schritt 1, Bild 3 von 3
    • Locate the hard drive enclosure release latch in the top left corner. While pulling it down, lift the enclosure up and out of the laptop.
    • You may need to use a spudger or mini flat blade screwdriver to grab onto the lip of the drive enclosure and pull it out.
  2. Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 2, Bild 1 von 3 Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 2, Bild 2 von 3 Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 2, Bild 3 von 3
    • Flip the drive black side down.
    • Place six opening picks between the black outer casing and metallic inner casing to disengage the five metal clips connecting the inner and outer casings.
    • Once all the clips have been freed from their holes, you can now lift the inner casing up and out of the outer casing.
  3. Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 3, Bild 1 von 3 Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 3, Bild 2 von 3 Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Gently pull the hard drive assembly from the inner drive casing.
    • Using a spudger, gently remove the two adhesive pads holding the paper dust cover in place.
    • If you have a replacement dust cover, you can simply just cut the old cover off. You will need new adhesive pads if you have a new cover or are reusing the old one.
  4. Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 4, Bild 1 von 3 Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 4, Bild 2 von 3 Panasonic Toughbook CF-53 Hard Drive Replacement: Schritt 4, Bild 3 von 3
    • Remove the SATA adapter from the hard drive by simply unplugging it.
    • When reinserting the hard drive into the drive cover, ensure that you line the circuit board of the SATA adapter with its slot. This is the connector shown in the final image.
Abschluss
3 weitere Personen haben diese Anleitung absolviert.
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 17
Letzte 30 Tage: 107
Insgesamt: 7,168
