Einleitung
This guide demonstrates in detail how to remove and replace a Pandigital Super Nova front facing camera in order to preserve the function of the camera. See the battery replacement guide for instructions for taking off the back cover.
Was du brauchst
Remove the screw covers from each corner of the back side of the device.
Set aside.
Using a Philips screwdriver, remove all four .15 mm screws from each corner.
Set aside.
Use a metal pry tool to separate the camera and the small clip that holds it in place.
Use a pair of small tweezers to gently pull the camera connector out of the motherboard.
