Einleitung
This guide demonstrates how to remove and replace a Pandigital Super Nova screen in order to preserve the function of the device.
Was du brauchst
Remove the screw covers from each corner of the back side of the device.
Set aside.
Using a Philips screwdriver, remove all four .15 mm screws from each corner.
Set aside.
Use a metal pry tool to separate the camera and the small clip that holds it in place.
Use a screwdriver to remove the six .15 mm screws that hold the motherboard in place. Set aside.
Remove the eleven screws that hold the screen to the base. Eight are .15 mm and three are .11 mm.
Lift the motherboard out of the tablet.
Remove the second connector between the screen and the motherboard.
Pry the silver screen box from away from the device.
Open each of the four clips securing the screen box to open it.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
