Einleitung
Warning: This replacement guide may require the use of a soldering iron unless your replacement screen has speakers, microphone, etc. already attached.
This guide will show you how to remove the screen from your phone and replace it with a new screen.
Was du brauchst
Near the hinge of the phone there is a green circuit board.
On the underside of the board, there is an orange plastic connector that connects the battery to the screen.
The LCD screen is the metal square with the black LCD screen in the middle (this should not be confused with the clear plastic protective screen on the front of the phone).
Pull the LCD screen out with your fingers and disconnect the circuit board from the orange plastic connector with the spudger.
Carefully remove the screen. Leave the wires from the speakers exposed (top of the phone).
Reattach the backing of the phone with the four screws.
Your phone should now be operational (after reinserting the battery). If it is not, revisit the steps, and make sure everything was reassembled correctly.
If your phone turns on and displays, you are finished!
