Zum Hauptinhalt wechseln
Pantech Matrix Speaker Replacement
Was du brauchst
  1. Pantech Matrix Speaker Replacement, Phone Orientation: Schritt 1, Bild 1 von 1
    • Place phone with screen side facing toward you.
    Frag FixBot
  2. Pantech Matrix Speaker Replacement, Phone Orientation: Schritt 2, Bild 1 von 1
    • Flip phone over so screen side is now facing down.
    Frag FixBot
  3. Pantech Matrix Speaker Replacement, Remove Back Cover: Schritt 3, Bild 1 von 2 Pantech Matrix Speaker Replacement, Remove Back Cover: Schritt 3, Bild 2 von 2
    • Gently slide the backside phone cover off exposing the battery underneath.
    Frag FixBot
  4. Pantech Matrix Speaker Replacement, Lift Battery: Schritt 4, Bild 1 von 1
    • Carefully lift the battery up from where the spudger is pointed.
    Frag FixBot
  5. Pantech Matrix Speaker Replacement, Remove Battery: Schritt 5, Bild 1 von 1
    • Remove the battery from its dock.
    Frag FixBot
  6. Pantech Matrix Speaker Replacement, Slide SIM Card Out: Schritt 6, Bild 1 von 3 Pantech Matrix Speaker Replacement, Slide SIM Card Out: Schritt 6, Bild 2 von 3 Pantech Matrix Speaker Replacement, Slide SIM Card Out: Schritt 6, Bild 3 von 3
    • Slide the SIM Card out of its dock.
    Frag FixBot
  7. Pantech Matrix Speaker Replacement, Remove Phone Screws: Schritt 7, Bild 1 von 2 Pantech Matrix Speaker Replacement, Remove Phone Screws: Schritt 7, Bild 2 von 2
    • Use a Phillips screwdriver to remove the four 2mm Phillips #000 screws from each corner of the device.
    Frag FixBot
  8. Pantech Matrix Speaker Replacement, Remove Phone Casing: Schritt 8, Bild 1 von 3 Pantech Matrix Speaker Replacement, Remove Phone Casing: Schritt 8, Bild 2 von 3 Pantech Matrix Speaker Replacement, Remove Phone Casing: Schritt 8, Bild 3 von 3
    • Rotate the phone so the base is facing you.
    • Use spudger to separate phone casing and inside as shown.
    • Remove the casing carefully and set aside the rest of the phone.
    Frag FixBot
  9. Pantech Matrix Speaker Replacement, Remove Phone Speaker: Schritt 9, Bild 1 von 2 Pantech Matrix Speaker Replacement, Remove Phone Speaker: Schritt 9, Bild 2 von 2
    • Place the spudger in the notch on the side of the speaker as shown.
    • Use the spudger to gently pry the speaker loose from its dock.
    • Remove the speaker fully from the phone.
    Frag FixBot
Abschluss
Zeel Patel
1.096 Reputation
9 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 8
Letzte 30 Tage: 56
Insgesamt: 402
