Einleitung
Use this guide to replace the mainboard and navigation board in your Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
Was du brauchst
Einführungsvideo
Disconnect the battery by pulling the two red wires apart.
Remove the battery by releasing the battery retaining straps.
Turn the drone upside down.
The cover is held on by plastic tape. Peel off the tape and use a spudger to remove the back cover.
Using a spudger, separate the connector for the downward camera.
Remove the camera from the body by pulling it off the foam body.
Use a spudger to release the black retaining clip. Then disconnect the connector to the sensors.
Use tweezers to carefully remove the ribbon from the connector.
Remove the four 8mm torx screws with a T6 bit.
Remove the four 8mm philips head screws with a PH00 bit.
Turn the drone right side up
Remove the USB connector from the battery retaining straps.
Turn the drone upside down again.
Use a spudger to release the connector and carefully remove the ribbon.
Lift the mainboard up so that you can access the back.
Disconnect the first connector with the white wires using a nylon spudger.
Disconnect the second connector with the red and black wires using a spudger.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
3 Kommentare
hey man, you make it too easy
Hi i am in need of the mainboard. I dnt know where i can buy 1. Any advice
I WISH I knew if this would solve my drone issues. I am a disabled teacher & biologist. I was bought the AR drone 2.0 to help keep me in good spirit as I no longer had the strength 2 hold a dslr steady. My father set everything up and he had 1 successful flight. The second flight my dad again just wanted 2 do a simple flight and it just dropped out of the air from 5 feet into grass. IT HAS NEVER WORKED SINCE :( We tried the local hobby store where
I purchased got no help only wanting 2 sell new drones. We get a message saying "UNKNOWN ERROR" since 2013 or 14 I think i have tried everything that you tube says 2 check. : No broken crossbars, blades,gears etc. Resetting will get rid of warning then will not get more that 1ft off the ground and then goes where it wants once it even held its altitude.
So any help is gr8t. Don't have $ to waist with all medical care
