Zum Hauptinhalt wechseln
Parrot AR.Drone 2.0 Motor Replacement
Was du brauchst
Einführungsvideo
  1. Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: Schritt 1, Bild 1 von 2 Parrot AR.Drone 2.0 Motor Replacement, Propeller and Gear: Schritt 1, Bild 2 von 2
    • Remove the foam body.
  2. Parrot AR.Drone 2.0 Motor Replacement: Schritt 2, Bild 1 von 2 Parrot AR.Drone 2.0 Motor Replacement: Schritt 2, Bild 2 von 2
    • Disconnect the battery by pulling the two red wires apart.
    • Remove the battery by releasing the battery retaining straps.
  3. Parrot AR.Drone 2.0 Motor Replacement: Schritt 3, Bild 1 von 1
    • Remove the small retaining clip using a plastic opening tool.
    • Be careful as these clips can fly off and can be difficult to find.
  4. Parrot AR.Drone 2.0 Motor Replacement: Schritt 4, Bild 1 von 3 Parrot AR.Drone 2.0 Motor Replacement: Schritt 4, Bild 2 von 3 Parrot AR.Drone 2.0 Motor Replacement: Schritt 4, Bild 3 von 3
    • The propeller, gear, and rod can be removed by simply lifting them off the motor.
  5. Parrot AR.Drone 2.0 Motor Replacement, Motor: Schritt 5, Bild 1 von 2 Parrot AR.Drone 2.0 Motor Replacement, Motor: Schritt 5, Bild 2 von 2
    • Disconnect the connector at the bottom of the motor assembly.
  6. Parrot AR.Drone 2.0 Motor Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 5mm screws on the top of the motor assembly with a PH00 bit.
  7. Parrot AR.Drone 2.0 Motor Replacement: Schritt 7, Bild 1 von 1
    • Remove the three 5mm screws on the bottom again using a PH00 bit.
    • The three screws from the top are different from the three screws on the bottom.
  8. Parrot AR.Drone 2.0 Motor Replacement: Schritt 8, Bild 1 von 2 Parrot AR.Drone 2.0 Motor Replacement: Schritt 8, Bild 2 von 2
    • Carefully wiggle out the motor assembly out of the arm.
Abschluss
5 weitere Personen haben diese Anleitung absolviert.
David Hoyt
4.023 Reputation
43 Anleitungen geschrieben
Cal Poly, Team 25-89, Amido Spring 2010 Mitglied von Cal Poly, Team 25-89, Amido Spring 2010
CPSU-AMIDO-S10S25G89
4 Mitglieder
63 Anleitungen geschrieben
2 Kommentare
are the motors different on each side?
dbksoft - Antwort
I need to know this also. replaced cross.member but did not put motors in original spots now my drone goes crazy and erratic
Steven Maloney -
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 3
Letzte 30 Tage: 15
Insgesamt: 5,755
