Einleitung
Use this guide to replace, propellers, shafts, and gears on a Parrot AR.Drone 2.0.
AR.Drone 2.0 spare parts and mounting tools are available from several Parrot retailers.
Was du brauchst
Einführungsvideo
Disconnect the battery by pulling the two red wires apart.
Remove the battery by releasing the battery retaining straps.
The propeller, gear, and rod can be removed by simply lifting them off the motor.
4 weitere Personen haben diese Anleitung absolviert.
