Einleitung
This guide will show the steps needed to remove the GPS Module. In order to remove the GPS Module, the nose will have to be removed first. Removing the GPS Module will require disconnecting the wire connections on it.
Was du brauchst
Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
Remove the two 6mm T5 torx screws holding the GPS module. There is one screw on each side.
Remove the 4mm T5 Screw holding the GPS Module.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Ein Kommentar
With voice driving directions maps <a href="https://play.google.com/store/apps/detai...
">GPS Voice Nevigation with speed</a> limits with speaking ,user can get accurate gps coordinates for car GPS navigation.In gps driving guide 2019 users can listen to voice input for voice navigation which gives out all of the audio instructions for direction gps towards destination point on the maps
