Einleitung
The propellers are one of the most important elements of the drone when it comes to flight. Without proper placement, the drone will not be able to fly properly. This guide will teach you how and where to place the propellers.
Using the propeller removal tool (included with the Parrot Bebop Drone), line up the holes with the protruding screws.
While holding the propeller in place, rotate the tool counterclockwise until the screws are aligned with the holes on the propeller.
While gently pushing down on the arm of which the propeller is attached, pull the propeller up off the motor.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
