Einleitung
This guide instructs you to detach the main frame from the motherboard; this is intended to allow you access to the Shock Absorbers and prevent damage to the antenna or other motherboard cables. In order to remove the Shock Absorbers, the Battery, Nose and Propellers will have to be removed first.
Was du brauchst
Einführungsvideo
Once the battery is separated from the nose, push down on the connector and pull the battery away from the connector.
Remove the two 7mm T5 torx screws using a screwdriver. There is one located on each side.
Remove the styrofoam nose from over the drone's camera by sliding it towards the front of the drone at an angle.
Disconnect the two connectors that are attached to the front of the motherboard by gently pulling on the three wires.
Remove the four 5mm torx T5 screws on the bottom of the drone with a Torx Screwdriver.
Using both hands gently pull the two pieces of the frame apart until you can see the connectors under the frame attached to the motherboard.
Remove both of the connectors from the motherboard. There is one connector on each side.
Remove the four rubber shock absorbers by squeezing and twisting them while also pulling up.
