Einleitung
This guide will show you how to replace buttons on the front of a Parrot Flypad if they have stopped working. Follow the instructions carefully to successfully replace the front buttons.
Was du brauchst
Position the controller so the back is facing up.
Use a T6 screwdriver to remove the six screws on the back of the controller: four 0.9 mm screws and two 0.1 mm screws.
Remove the foam adhesive that connects the front plate to the motherboard
Use a Phillips #0 screwdriver to remove the two 0.7 mm screws.
Remove the motherboard from the front plate.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
