Einleitung
This guide will explain how to easily replace a dead or dying battery on the Parrot Hydrofoil Orak. A plastic opening tool will be useful, as part of the removal may hurt if you use your fingernail.
Was du brauchst
Orient the device so that the front of the boat chasis is facing to your right.
Use your pointer finger on one tab, your middle finger on the other, and your thumb on the bottom to pry the tabs away and lift the drone out of the holder.
Insert your plastic opening tool in between the tab with the arrow on it and the battery below it.
Pry the tool upwards to disengage the battery.
