Einleitung
This guide will detail the process for removing the lever arm on the hydrofoil boat. If the lever arm won't raise when the drone is powered on or is broken, you may need to use this guide to access and remove the lever arm.
Was du brauchst
Lift the lever arm from the slot it is in and slide off of the end of the plastic piece that was holding it to the boat.
Fast fertig!
Abschluss
