Zum Hauptinhalt wechseln
Parrot Hydrofoil Orak Propellers Replacement
  1. Parrot Hydrofoil Orak Propellers Replacement, Propellers: Schritt 1, Bild 1 von 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: Schritt 1, Bild 2 von 3 Parrot Hydrofoil Orak Propellers Replacement, Propellers: Schritt 1, Bild 3 von 3
    • Locate the propellers of the same angle, each diagonally across from each other.
    • Locate the propellers of the opposite angle, located diagonally across from each other.
    • Grip each white propeller firmly and pull up to remove.
    • Removing the propellers may require a decent use of force.
    • When replacing the propellers make sure to place the corresponding set in the right position, diagonally across from each other to ensure proper liftoff.
Abschluss
Cal Poly, Team 20-2, Livingston Fall 2016 Mitglied von Cal Poly, Team 20-2, Livingston Fall 2016
CPSU-LIVINGSTON-F16S20G2
4 Mitglieder
5 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 11
Insgesamt: 794
